RCU Forums - View Single Post - how do you fasten lead weights to model
Old 08-24-2017 | 07:06 PM
YellowBlueBird
The propeller is slightly off balance. Just a bit of clear poly on one blade might do it for the prop. The spinner on the other hand spins toward the low side with some authority. This is most likely where the vibration is coming from. How do you balance an aluminum spinner?
Jerry
