RCU Forums - View Single Post - New Composite ARF SU27
Old 08-24-2017 | 08:30 PM
  #298
Craig B.
Originally Posted by DrScoles
Craig, how finicky was your hydraulic install on the Mig?
Hey Mike, PITA.....the trouble is getting the residual air out of the lines near the cylinders. No matter how hard you try there will always be a little air in the cylinders that comes out with repeated cycling and in long runs it will just snorkel up and down the lines from the cylinders. I will install a T fitting nearby to bleed off that air but the whole process is very messy. Air all the way unless you absolutely have to go oil IMO.
