RCU Forums - View Single Post - Phoenix v5.5 with SD-10G
Old 09-02-2017 | 12:10 PM
rlemaster's Avatar
rlemaster
Default Phoenix v5.5 with SD-10G
I just purchased Phoenix version 5.5 and along with it, purchased the adapter that HorizonHobby lists as being compatible with Sanwa/Airtronics transmitters. Unfortunately, this adapter will not work with the SD-10G. The adapter they recommend (RTMAAIRSAN) has a large 5 pin DIN connector on it. The SD-10G, on the other hand, appears to need a 4 pin mini DIN connector.
There are some adapters that look closer to what I need, but that's only from a physical fit point of view, I have no way to know if they are wired correctly. Also, I've found some references online that say how to make one using an S-Video connector. That isn't a problem for me, but there are at-least two versions of it with different wiring diagrams.
Has anyone successfully gotten the SD-10G to work with Phoenix's cable?
Russ
