Ken, yes they will be the same. They may look a little different in the pictures due to a very slight difference in span right now. The next step is to sheet the bottom wings while making wing tube sleeves. Once the wing tube sleeves are done and installed in the upper wings I can move forward and sheet the top wings. After that I can perfect the transition between the fuselage and the top wings.
Now a question for the masses again. I picked up a Hacker C50 12XL Acro over the weekend. I did a test run today after setting my speed control to 2 poles and 3 degrees timing. I ran it without a prop and noticed that it did run very smoothly but it got much hotter then I would have anticipated. I'm just wondering if this is normal. It go about the same temp as my Dualsky outrunner after a flight.
