RCU Forums - View Single Post - Pattern Biplane
Thread: Pattern Biplane
Old 09-16-2017 | 04:59 PM
  #57
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
First wing panel is in the bag. My process on this one is quite simple. Once the core is kissed with a little 120 grit it is cleaned very well. The wing sheeting has been seam taped together. I don't like to glue them together as that leads to ridges. For this one panel I mixed up 60 grams of laminating resin and spread just enough on the sheeting to give them a bit of a sheen. The sheeting was placed on the cores and then placed in the shucks with 2 mil plastic between the sheeting and shucks. There is 1/4" press board glued to the outside surface of each shuck to help with maintaining consistent pressure on the shucks. The same shucks will be used for all cores to maintain consistency. After a 12 hour cure, the next core will get done.
