Originally Posted by
Acs_guitars
Here is the Ventrix I put together for AU Tiger... We didn't measure after adjusting the CG, but I started with it set to the rear-most mfg spec and we found it seemed nose heavy so I moved the RX batteries back to just in front of the fuel tank. This cleaned up the rolls since we could take out the elevator trim and inverted flight took very little elevator. I got a flight on his Ventrix and it is a great flying jet that's easy to feel confident with. It has excellent speed, tracks like its on rails, and does nice big loops without petering out at the top. I'd say the K-100 is a perfect match.
Just got got the ventrix,What CG would you use
