Originally Posted by
handyman
thanks.....what about the angle of the motor.should that be stright on or angle up....?
Have your thrust line parallel to the waters surface on plane. It will take some experimenting to get this part just right. Generally, I set my engines to have he prop shaft parallel to the keel of the boat which generally is parallel to the water when underway.
