RCU Forums - View Single Post - dumas air boat help
Old 09-23-2017 | 03:14 PM
Got RPM's Avatar
Got RPM
Cool
Exactly what motor are you using? The “watt output” means little. Regardless, that prop is-probably not the best for the motor unless it is a pretty large one. Too, exactly what ESC and cells are you running?
The reason for poor left turning is usually due to prop torque. As above, larger rudders will help. So will a smaller prop, but we need the above info to make an intelligent recommendation.
