RE: Establishing proper CG before covering
I balance the plane laterally (wingtip to wingtip) with all gear installed before covering. Then add any weight inside the very last rib bay on the light wing. I tried to balance front to back once and that didn't work out too well. There is a surprising amount of covering weight behind the CG it seems. I ended up having to counter the weight I added to the tail before covering (the weight was now buried in the tail with epoxy).
