Thanks Joe I tried to laminate a foam fuse with 1/8" ply from the lumber yard and it weighs a ton. The fuse alone weighs 1 lb. I haven't cut out the lightning holes or cut out for the wing yet but it looks to be quite heavy now. Once I decide this is a bust I'll try the veneers. My 1/8" ply was only 8 bucks for a 4x8 sheet so it is really cheap to build multiple fuses plus fast and easy. I want to make sure this method won't work first it's just too cheap. I really like to fly crazy so if I can build these suckers cheap and fast I'll try anything once.
