Okay, so what have I got wrong here.......I'm trying to set up the spoilers using Hitec HS-55 servos but cannot get the spoilers to go either full up to 90* or down all the way. If I adjust the servo arm to set the spoiler down all the way I cannot get the spoiler back up to 90* even with all trims and end points set. I'm using a Hitec eclipse 7 radio. The servo arm is the longest one for it.
Either I have the geometry not quite right or my radio wont adjust that far. I'm using ch.5 ( usually for gear) but maybe I should look into using the flap switch.
Now looking through the manual I see that I need to set up the radio for glider function so I'm going to check into that as well.
Maybe I'll get lucky.
