Hi Chic,
Thanks for all the information! I was planning on doing something similar, and have a used a similar approach on other airplanes. I have a couple more questions, and hopefully I will stop bugging you
- What is the outside diameter of the carbon tube you used? And the inside diameter (or wall thickness)?
- What is the diameter of the G-10 horn at the tube? What thickness G-10 di you use? For the horn what was the reason for having it curve forward? Was that to keep the ball joint on the hinge line?
- Where did you buy the carbon rod? What type of tube is it (Roll Wrapped Carbon Fiber Tube, Braided Carbon Fiber Tube, Pultruded Carbon Fiber Tube)?
Once again, thanks in advance for your assistance!
