RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 10-03-2017 | 08:33 AM
  #172
Xpress's Avatar
Xpress
Originally Posted by Fernando
Dear members:
I´m trying to solve a programming issue with an aurora 9x TX and an Optima 7 receiver.
The plane in wich I´m making the instalation requires two elevator servos. One is plugged at channel 2 ant the other one is plugged in the channel 5 slot. I use the p.mixes and determine the master and the slave channel, but after that, i dont have any idea in what i have to do next in order to make this mix works.
Is there any explanation for dummies like me, you can recommend?
Thank you all
Fernando Bedoya
Bogota Colombia
You're overcomplicating it. Get rid of all P.Mixes you have for the Elevator servos. Navigate to the Channel menu in System, select the 5th channel and set the function to Elevator (I.E. if it says AUX1, tap on AUX1 and then tap on SEL. in the bottom right, then select ELEV, then tap SET in the bottom right). From here on out Channel 5 will always act as an Elevator channel and will be controlled the same as Channel 2, regardless of what trim tab settings you input, or what D/R or EXPO settings you set. You can set sub-trim independently in the SUBTRIM menu as well as end points in the EPA menu to ensure both elevator servos are matched at the centers and the end points.
