Curare Rebuild.
I'm going to go for the original Hano paint scheme. All the Monokote wrinkles were taken out of the wing with a heat gun. The center section of the wing is Monokoted.
The dings were repaired with balsa filler and Monokoted. The covering is scuffed with a scratch pad and is to be primed. Also the aileron horns were straightened, cleaned and re-glued to the wing. The main gear is removed to be straightened. The retracts are Spring Air. I have tested and they work.
