RCU Forums - View Single Post - Webra 6.5ccm engine?
Old 10-09-2017 | 10:55 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
For peace of mind, replace both bearings. You will probably need to remove both bearings and measure them to get the proper size replacements. Bearings are catalogued by their ID x OD x Width. When you search for bearings, use that format to find the proper bearings. Some Asian and European engines use an SAE seized front bearing - like the R6 and a metric rear bearing.
