rudder
Go up until you reach wood and use the wood shim to give correct angle. I knotch into rudder and wood and aeropoxy horn in. I also go inside rudder with a little areopxy and on bottom inside. If you dont find wood to go into like the instructions show then you have a problem.
Scott
