Originally Posted by
speedracerntrixie
Quite a productive day today. I was able to get the bottom wing lined up and mounted. It is sitting at .7 degrees incidence as measured using the upper wing as the reference. The upper wing is set to zero using the nose ring as a reference that is set to one of the seams along the length of the fuselage. I think I have used enough reference points to make sure everything is square. At this point the only thing that needs attention is there is a 1/8" difference in wing gap between the right and left side. Just a little fine tuning to the wing saddle on one side will fix that right up.
Looking like a plane now
Do you have any stagger on the wings?
