RCU Forums - View Single Post - YS DZ200cdi
Thread: YS DZ200cdi
Old 10-16-2017 | 02:43 AM
bjr_93tz
Originally Posted by drac1
Same fuel and standard YS plug.
Idle around 2k for landing.. I usually bump it up to 2100 while flying.
While not a DZ200, I set mine up so that the idle is as low as possible, then have it bump up a few percent when I switch to the spin condition to minimise the risk of a flame out. Also, I try to take advantage of the fore-aft movement of the engine in the YS mount by positioning the throttle arm so the aft movement of the engine during down-line braking closes the throttle a bit more, and the forward movement when at power opens the throttle a bit.
Not sure if any of it helps me but the placebo effect does wonders..
