Originally Posted by
born2build
I think Hydro Junkie has the right idea. In fact, I know he does. Model aviation was never intended to be a "grab-n-go" kind of thing, although the industry is doing their level best to make it so. Electric power has certainly come of age, but it gets decidedly expensive as you go up in size. I've flown the Apprentice for other people and it works well. There is one major drawback, though. The "Safe Flight" feature can (and does) become a crutch, a hindrance when it becomes time to turn it off, rather like kicking a cane out from under someone with a bad limp. The best advice I can give is to find an instructor and accumulate as much stick time as you can. You are, after all, learning how to pilot an airplane. The PT 40 (with ailerons) is an excellent choice for your first build. It is, after all, what it was designed for.
Glad you approve. You will notice that I didn't recommend a kit to build or power type. I figure personal taste would dictate which plane and what kind of power the OP would prefer. I've heard good things about the PT-40 and the Kadets, heck, I even have a pair of Kadet Jrs under construction from plans.
I was just browsing through Tower Hobbies website and found they carry:
PT series of trainers
Eagle 2
Kadet series of trainers
Any of the above would be a good first plane to build, if you want to build something while learning with the foamy
