Originally Posted by
jimkron
NIce Maiden Mike. I'm flying the FG 84 with some over-heating challenges.
Did you use the baffles from Keleo?
Did you use the pressure fitting off the Keleo exhaust?
What prop did you use?
Jim
I cut my own baffles with my CNC router, overheating is still a problem. I since modified the baffle around the top cylinder and opened up the cowl flaps. I am using a Keleo ring muffler but I didn't use the fitting, because I was advised that it was for smoke.
