I'm using a Zenoah G62 engine which is about 6 lbs. or so and no nose weight to balance at CG. That Saito better be around 6 lbs as well or you will have to add a # or 2
I'm going to go back down a couple degrees in engine thrust before next flight....got to fix the minor damage first from last attempt
