RCU Forums - View Single Post - Skymaster T-33 Build
Old 10-26-2017 | 10:42 AM
  #77
liemtran75
Originally Posted by FlyingJ664
The T-33 flies well and handles grass no problem with the large wheels. You do have to concentrate on the landings though- the narrow gear makes it easy to tip onto the wing tanks, and crosswind landings can be tricky
HI Jordan,
When you received your T33 from SM, was the main actuator already installed and air lines plumbed for the opening canopy option? I just received mine through Pacific RC and was charged for the opening canopy option, and the rep quoted "That is the extent of the operational canopy. They do not install it on this plane because it gets in the way while building it and you will end up removing it." I saw no actuator to close or open my canopy at all.
