RCU Forums - View Single Post - Difference between Bandit Mk1 and Mk2
Old 10-26-2017 | 07:53 PM
roger.alli's Avatar
roger.alli
An “Original Composite” Bandit is a different model than either of the BARFs, but they do share the same wing spar system as the Mk I BARF.
The big deal with field assembly is the forward wing spar has an in-board bolt which needs to be accessed from the belly pan. (Remove and refit belly pan for each assembly) Not sure you can get around this.
My suggestion,
  • Leave the stabs and fin on.
  • Fit the EZ connect air system.
  • Fit a 6 pin plug for the electrics in each wing.
Fitting the wings only, should not take more than 5-6 mins.
Original Bandits are the coolest.. :-)
Some long nose pliers or forceps are a good thing to own..
