Originally Posted by
jimkron
Report: Flying Sunday with cowl mods went well. Saito FG 84 and Keleo exhaust ran cool in the air with average temps around 177f. Ran two flights without pressure fittings. Everything seemed fine. Still tweaking midrange.
Jim, Good to hear you are conquering the heat problem. I have a couple questions.
1. Did you notice the temp when the engine died from over heating?
2. What effects do you think pressurizing the fuel tank did or didn't do?
3. Are you running the Ray English recommended 15.1 mix? And what kind of lube are you using?
Gary
