If you are using a metal pushrod for the throttle, you may want to replace it, that can cause interference as experienced with low frequency vibrations. Either use a throttle cable or use a nyrod. Also verify that neither antenna is near any metal including servo leads. I usually mount mine against the side of the fuse with one facing vertical and the other horizontal. Made the mistake of doing it a different way and nearly lost the plane to interference.
