Originally Posted by
DGrant
There's a set of plans(or something I recall that you can build from).. somewhere.. I know I've got some info here in my computer somewhere. I'm glad to see this thread coming around again too. The above plane was tempting to me also when it first came up... ha..
My Kommander Resto is in much better shape lately, as it cleaned up well. I got it to a stopping point, and shelved it for a bit to work on other planes... but it's definitely going to get done. I've got the new canopy, as well as the cowling too... so I've invested a little into my "free" Kommander... ha. I've got to build a new hor.stab/elev... and it will also get new ailerons... all stock to do so is already on the shelf with the plane... I have tried to use as much original parts as I can though.
I will look into any info I might have to plans... If memory serves, aren't they in like 2 or 3 sheets?... and you splice to make them full-size?... or... hmm.. I'll look around here though.
Excellent info on the wing supplier!!! Thanks for that.. . that's awesome. I thought early on I might need a wing ... as the one I have has a huge repair in it that I didn't see until I got it uncovered.. but I worked on it a bit and determined the repair is sufficient and will be undetectable once covered... but if I want to build another one(or many more).. that wing info is excellent! I'll get back here with plan info... It might even be already in this thread too... very possible. Cheers!
If it helps, I've got Kommander plans on my website, including the instruction booklet and wing template. Check out
https://wanderings-ds.jimdo.com/sig-rc-kits-21-40/ - about half way down the page is the original Kommander & the Mk-II - - kits RC-32.
