When it comes to plating, not all base metals will accept chromium, and need a nickel layer applied first. That is what two step is all about. That is also how they plate plastic by applying a submetal that can adhere to plastic and that chromium can adhere to. The layers are micro thin too. A proper chrome job though will use a base layer of copper which is then polished smooth prior to plating with nickel. Nickel is used as the filler metal, and the chrome is extremely thin.
