ttdflight, I have not built this kit. I do know it has a habit of coming out a bit heavy..
I would make sure you use very light wood in the back and keep the covering, tail skid as light as possible. I think pull pull on the tail surfaces will save you a ton of weight up front to balance later.
A friend built one and tricked it all out.. It was a hand full and ended up having the most scale like wing failure I have ever seen.
oops, I replied to the wrong person, changed the name..
