The hissing sound comes from the valve but the leak is on your air cylinders somewhere.
Use pliers to cut air flow from retract cylinders one at the time and when hissing stops you have found the leaky one. I have had similar problems and my culprit was UP door cylinder and once in my skymaster f-15 had a leaky retract cylinder.
