Originally Posted by
Lifer
Well, at least the 2 pounds of ballast should tell something!
Yes and no... I guess my question is just too open for different variables like battery size used on ignition and rx, plus wheel type used as any plane would. I should have really thought about that prior to even posting such an open ended question. So it is hard to give me what I want unless the person will be using simular weighted items like a 2000mah nimh Battery for ignition, 4200mah nimh for the rx and a 2000 mah nimh for the retract system with the factory main wheels and a robart tail retract and similar weighted prop.
example: I had guys tell me I would need to add weight to my P-40 with a DLE 55 but with the same items above the plane balanced perfect with everything mentioned above in the factory locations with full retract setup and xoar prop.
sorry guys just wanted to clear things up so you are not thinking I am trying to be a butt.
Thanks again for your inputs...
