Originally Posted by
RemoteJets
If you ordered at Tamjets a K45 version then it should be the right one, only a little smaller then the Grumania version.
The outside diameter of the Grumania pipe for the K45 powered Mini Avanti S is 70mm (inner about 65mm).
Whit this pipe installed the carbon rod of the stabilizer just press on the pipe and keep it in place.
Grt,
Berto.
My internal diameter is only 50mm so not looking good. Also I am not sure how far the mouth of the pipe should be from the back of the turbine.
In in the Kingtech manual it shows 20-30mm for most of the other turbines but not the k45?
