Originally Posted by
controlliner
The ABN LA 65 has a tighter piston fit, hence the better RPM than the PAW. larger throttle bore too?
No, the timing and size of port is difference between OS LA 65 and PAW 60 TBR, also OS LA 65 has better timing and the larger ports to run at higher revolution.
