RCU Forums - View Single Post - Vt80 help
Thread: Vt80 help
Old 12-11-2017 | 12:50 PM
gooseF22's Avatar
gooseF22
yes, when its cold it ramps slowly, make sure to use fresh battery when its cold charged to 4.1, not 4.2 unless you kept the battery indoors..
When you do a cold weather start, its much harder to ramp the fuel up and keep the heat into a kero start. if it stagnates at 70 degrees, then up the igniter by .2 I use 6.4 to start. also you can slow the fuel ramp in gaspar's ecu. thats good when its very hot, or very cold
