Originally Posted by
raron455
I am on the other end of that brand, I have had 3 Sullivan skywriter pumps fail in 2 years,,they are junk imo, two of them had the motor spin in the housing and tear the leads off the motor, not to mention the case had oil in it on the backside of the pump, my last one had a board failure after about 6 mos. Maybe they used to be made better, but the ones I bought recently,, no good, the one I have in my 3d plane has been in there for 5 years,no trouble go figure??Ravill is right, the price is good. The POWERBOX pump is good, the kingtech pump is supposed to be good as well.
I am currently using a kingtech fuel pump with a brushed ESC for my smoke on my lightning,,works great tons of smoke
You know, now that you mention it, I had 1 pump die 7-8 years ago. The motor stopped working. But other than that, I've had WILD success with them. Go figure. I don't even run filters.
I also like the right upper 2 position switch. I mix smoke with throttle, so it takes two events to start smoke in my jets.
