RCU Forums - View Single Post - Sig Kavalier
Thread: Sig Kavalier
Old 12-14-2017 | 05:15 PM
mkjohnston
Originally Posted by hsukaria
I have a few choices, but most likely a Super Tigre G51. I also have an OS 46SF, so either one, they weigh the same with same performance. If the build comes out real light, less than 4 pounds, I can try a Fox 40 small-case, that is about the same weight as the OS 35AX.
I think Fiberglass Specialties makes a fiberglass cowl for the Kavalier if you don't like the plastic one. I don't have experience with plastic cowls, I will try it and see. I like planes that have the cowl built up from wood that is integral to the fuselage, like the original Kaos, UltraSport, even the Sig Wonder. That gives the cleanest lines, IMHO. But the Kavalier has the funky engine mounting at 45 degrees, but maybe that can still be built up from balsa blocks if you are so inclined. Hmmm, maybe I will consider that for my Kavalier build.
I like the OS Max 46 SF its a great engine and I found one on ebay for 120 bucks. The seller claims he replaced the front and rear bearings because of the age of the engine. It was nice looking but I have my eyes on a new Rossi 45 and I hope to purchase that soon. It would be way over kill for the Kavalier but I have new in the box mint Tower Hobbies Kaos to build after I finish this kit.
