Engine length
the dr1 was designed for g23. The g26 sticks out may be a 1/4”-1/2”. Should be fine with no mods. So far the only thing I deviated on was adding blocks behind hinge points.
undecided if I want to go with ca or pin hinges. Designed for ca i believe. I did add shear webs to top wing as well. All theee wings are done except the strut supports mounts in all three. I started stick framing one side of fuse last night.
Barry
