I have a Kavalier kit I plan on building this winter. I have a couple of questions:
1. How hard is it to build it as a taildragger? It has a one-piece elevator with the control horn in the center with the fuselage open to pass the pushrod out. I will keep it stock if it is too much trouble to convert, however. I fly off a grass field.
2. Has anybody built up the nose/cowl with balsa block instead of the included cowl? I like the continuous, uninterrupted lines of the old-style balsa block cowls.
Thanks.
