RCU Forums - View Single Post - Pattern Biplane
Thread: Pattern Biplane
Old 12-23-2017 | 07:59 AM
  #233
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by Pylonracr
Well, it sure hasn't gotten any more attractive in the past few weeks has it? Still U***. I am trying my best to be politically correct. As I look at the plug in the parting flange I see a lot of compound curves and a lot of square corners. After the surface coats, carbon tow and filled resin corners are down, I would consider laying the first layers of fabric and bagging it. I realize it is extra work, but I would want to ensure no air pockets and complete surface contact with the initial fabric layers especially if you could get 5 or 6 layers on in the first lamination. If you end up with some small air pockets after that it is not that big of a deal since they would end up deeper in the finished laminate. You may be able to get a perfect mold with just wet layup, but I don't think I would want to try.
Scott
Vacuum would crush the plug. It's just going to take some time and thinking things through to get the first couple of layers down without voids. If it were easy, everyone would be doing it.
