Other picture. The cat was asking if she can ride the jet
CG related
One thing I noticed on the plans regarding CG is that it tells to measure it from bulkhead WJ2, when the wing is on and you measure the CG you most likely will be measuring at the wing leading edge where it meets the fuse which is about 1/2 inch back from WJ2 position.
