RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 12-27-2017 | 05:49 AM
  #2280
EQ1
Originally Posted by Maxam
You will notice the heads are no longer screwed on, rather there are now 4 or 5 head bolts. UMS started to have real trouble with leakage between the cylinder and the head, especially with the 160 gas. -Tom
Tom, could you please explain, why bolts rather than screws will be better with repect to leakage? As an engineer I would say that the pressure between the connected parts, put on to the gasket, will seal everything. And the pressure will be the same using bolts or screws, just depending on the torque on the screws/nuts. Thanks for any further insight.
