RCU Forums - View Single Post - Tri-phan - thrust vectoring tri-copter by monophan
Old 12-27-2017 | 12:23 PM
UN.RCONT.OL's Avatar
UN.RCONT.OL
The best test so far. I operated the sensor right below the sensitivity level where it oscillated yesterday and the same focal length. In fact, I set the maximum sensitivity to that level. So, I can adjust it up and down with ch5. I took it as high as I felt comfortable, probably around 125-150 feet. It started to drift a little as it went higher but didn’t lose the position hold. I guess that is normal as there will be relatively stronger winds up there. Didn’t touch the sticks while in pos hold mode. Still WAY better than my experience with GPSs.
So Far I am very happy with the results. Next step is to install an OSD and FPV cam so I know how high I am going, etc… I want it to be able to hold position as high as 300 feet. Further tests will show if the current setup is capable of handling that. There is a chance that I will need to automatically increase sensitivity as it goes higher. As you know the objects which are further away seem to move slower. I am pretty sure this will be the case with the optical flow sensor and the sensitivity level close to ground may not be able to provide a tight pos hold at higher altitudes..
Future videos will most likely be aerial videos with some on screen information. I also want to test it in higher winds and do necessary tuning to be able to beat some strong winds.
Thanks for following.
https://www.youtube.com/watch?v=cyaaD0gma0M
