Originally Posted by
Square Nozzle
Lazer Works Engraving and Design ( lazer-works.com) did a fine job for me in my latest short kit. He uses quality plywood (5ply) not light ply and the typical junk wood found in ARF's. He gave me good direction on parts that I wanted to modify and delivery was as promised.. Look at his web site and you'll find hundreds of available short kits. He does not provide full kits. I got my standard sheet stock from National Balsa. Good stuff and you can specify different grades of wood for various applications
LazerWorks is local for me so I'm probably a little biased. Eddie puts a lot of effort into his cut files. I've built several of his kits and have seen a number more flying locally. He sells good stuff.
