Did you use a polyurethane base coat / clear coat scheam? They have a single stage urethane I was also considering. I am concerned about an entire clear coat adding weight.
Rick, you mean when you order say the 2.3M Extra from Composite-ARF you can get either a single stage urethane or the clear coat scheme as an option? I thought they painted them all the same.
