RCU Forums - View Single Post - 2008 the year of the Turbinator
Old 01-05-2018 | 09:58 PM
  #564
2walla
My Feedback: (10)
Originally Posted by CARS II
What I understand is that since these are used on giants and giants are usually painted then you can remove the pins to remove the control surface to service it, repaint it, recover, ECT, ect.
yes, you are correct, the ends of the pins will be bend at least 90° and they may be trimmed some so they don't interfiere with the control surfaces.
when i use the large dubros i try to run a single piece of piano wire thru all and secure it on one end of the surface. . this way you an easily remove the surface and part of the gap is filled by the piano wire. bending all those cotter pins is a pain...
