RCU Forums - View Single Post - 2008 the year of the Turbinator
Old 01-09-2018 | 03:46 PM
  #566
smoknrv4's Avatar
smoknrv4
Originally Posted by CARS II
Working on the wing now, I fitted the flaps to the wing before but, once the wing is mounted on the fuse it has to be done again, the last thing to add to the wing is the fiberglass strip to the center.
Carlos do you plan on installing the flap hinge ply covers on top of the hinges? That will be a bit of a pain when covering the wing I think. I'm debating wether to hinge that way or to hinge the way Dan seemed to with the robart hinges drilled into the trailing edges on a angle instead of just under the surface as per plan.
