Originally Posted by
FenderBean
Can someone explain the canopy lock, does it just slide forward once closed and the two metal rod ends at the end push into the front frame? Thanks
on mine and another I saw the entire canopy mechanism was installed backwards at the factory.... Best part is they don't give you any pics or instructions so you have to assume they did it right... Well they don't. I spent a very huge amount of time getting the canopy right.
also in order to make it reliable I did lots of mods to make mine work.
