Originally Posted by
bill_delong
So you got the servo wet and it's not waterproof, correct?
Sounds like you damaged the servo to me if that's the case, also possible you may have damaged your Rx too if it also got wet.
+1 to swapping channels to test both servos to verify if the servo is bad or if the Rx port is bad
Hey guys, so yeah I got the servo semi-wet, like I do all my servos. The servo and RX were both perfect after my run on pavement with some wet ground/snow. I always make sure to whip down my rigs and do my very best to get the water out with what I have (I need a damn air compressor), but I've also been doing this for many years with many different servos (all not water proof), never had a problem. Maybe I got very unlucky this time, as I should have done a better job of going over it, but that's weird to me, as it's never happened before. Yes, I've switched out both channels, and came to the same conclusion/problem that the servo works when it wants to. I will pull the trigger, sometimes the servo will engage, sometimes it won't. Weird. Thanks guys
