Blue Block replacement
I use Marvel air tool oil or any other air tool oil and you will be fine. Sounds like you are using common sense and yes the OS carb is a great improvement. The CH adapter is marginal due to the holes for the carb are off. You will need a tiny rat tail file to widen the holes.....or seek someone with a good lathe. -Tom
