Charging JST Lipo batteries
Have multiple batteries that I need to charge. If using this charge plug:
https://www.getfpv.com/multi-charge-...mm-bullet.html
can I set the charge rate by adding the mah of each battery and then charging ? or do I charge at the standard 1C rate for charging multiple batterys ?
