RCU Forums - View Single Post - Electron Retract battery source - potentially really dumb idea/question
Old 01-16-2018 | 10:23 AM
bluelevel's Avatar
bluelevel
My Feedback: (39)
Originally Posted by skunkwurk
I would consider using one of my RX packs, but they're both directly connected to a PowerBox SRS. I would either have to peel off one prior to the PB or use a spare servo port off of the PB just for power. If I use one of these ports I would have to step down the wire gauge as they are jr connectors rather than mpx. I would prefer to use the larger gauge wire to power the gear.
I am also using Powerbox products in all of my planes and never had a single issue with this setup for hundreds of flights. My batteries are mounted in the nose, so I need extensions anyway to connect the batteries to the PB. When I solder the extensions, I simply "Y" one branch with an MPX plug at the end. Works perfectly and as explained by Bob, the PB is smart enough to always use the battery with the higher voltage. This way they drain about the same, although one of them also powers the e-gear.
Thomas
